GS 1900-8 access problem
jroure
jroure Posts: 1 image  Freshman Member
Hello, ive just bought a second hand GS 1900-8 switch but i am not being able to access the GUI.
ive tried:
Reset the switch holding the reset button an then
1 - Connect PC on port 1, assign static ip 192.168.1.10, gateway 255.255.255.0. try to open 192.168.1.1 without success.
2- Connect switch to DHCP, use ZON to scan and it shows me the switch on ip 192.168.1.1, no success trying to enter GUI
3- tried to update the firmware(currently has v2.30 AAHH.0), i put 1234 in password (i reset the device so that should be the pass) but throws me "invalid administrator password"
dont know what else to try, any advice will be appreciated; thanks!
    is it unplugged from the router when you try 192.168.1.1?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    edited June 2025
    Hi @jroure
    Could you share the device's serial number with me? I will send you a private message for this.
    Zyxel Melen
  • Zyxel_Melen
    Hi @jroure,
    From the information in ZON screenshot, this device is more likely an project device. Please help to contact this ISP for support.
    You can contact the Telsur customer service in the following ways:
    By going here Centro de Ayuda | Sucursal Virtual | Pagar Mi Cuenta - Telsur - GTD
    By calling 600-800-4000 with any phone.
    By calling 105 with your Telsur phone number.
    Zyxel Melen
