Uplink a L3 switch with multi vlans to 700H via SFP.
2»
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,320 image  Zyxel Employee
    Hi @jef ,
    We assume that you want to add p3 (RJ45) and p14 (SFP+) to the VLAN10 interface as members, for example. Unfortunately, this configuration cannot be implemented due to a design limitation mentioned in our Release Notes.
    However, if you simply want clients connected to p3 and p14 to communicate with each other, you can configure p14 with a different VLAN. The firewall will handle inter-VLAN routing to enable communication between the ports.
    Zyxel_Judy
    Untitled Image
  • jef
    jef Posts: 92 image  Ally Member
    Thanks, I figured it out the hard way, but I appreciate the confirmation.
  • jef
    edited June 2025
    Can p13 and p14 be grouped together? Please say yes..
  • Zyxel_Judy
    P13 and P14 cannot be grouped together and must be configured as individual ports.
    Zyxel_Judy
    Untitled Image
  • jef
    Thanks, not the answer I was hoping for but still very much appreciated.
    Could this be resolved in future firmware? Because that is a problem, vlans are about grouping ports.
  • Zyxel_Judy
    Hi @jef ,
    In the next firmware version 1.35, USG FLEX H supports LAG over VLAN.
    Step 1. Create a LAG interface "lag0" and add members P13 and P14.
    Step 2. Create a VLAN interface and select LAG interface "lag0" as the member.
    Scheduled release time: in the end of July.
    To learn about enhancements, new features, and release dates, please follow the Firewall news & release.
    Zyxel_Judy
    Untitled Image
  • jef
    Thank you
