XMG1930-30 - Access L3 License - Flow Control
Hello!
On my site are 4x XMG1930-30 and 1x XS3800-28.
I want to test "flow control" on a XMG1930-30, so I bought a
LIC-ACSL3, Access L3 License for XMG1930-30
the activation was ok, the switch shows the license (after the reboot).
The site has no "Nebula Pro Pack". (status inactive)
Problem:
How can I activate "flow control" on a port?
In Nebula there is no option for "flow control" and in the web GUI there is also no option for "flow control".
Do I have to assign a license to every XMG1930-30 and the XS3800-28 or only to that switch where I will use "flow control"?
Thank you for your support.
mjr
Best Answers
Hi @mjr,
You don't need other license. This is because XMG1930 port setting option on Nebula desn't have flow control. Please access your device via SSH and configure it with CLI.
Here is the command:
#configure
(configure)# interface port-channel XX
(config-interface)# flow-control
(config-interface)# exit
(configure)# exit
#write memory
Zyxel Melen0 -
- XMG1930-30 with "Access L3 license" supports CLI configuration.
- Without "Access L3 license", you can SSH to XMG1930, but you can't use CLI configuration. Only support to show device information, like "show system", "show running-config", etc.
Hi @mjr,
#configure
(configure)# exit
#write memory
Zyxel Melen0 -
- 601 USG FLEX H Series
- 480 News and Release
