Siem Connection
Dpj
Dpj Posts: 194 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
Is it possible to connect nebula to SIEM?
Yours Dennis
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,051 image  Zyxel Employee
    Hi @Dpj,
    Nebula doesn't support connection with SIEM. If you want to monitor the traffic and/or security event, you may consider SecuReporter.
    Additionally, Zyxel Nebula supports exporting logs to a remote Syslog server. This is configured under Site-wide > General setting > Reporting > Syslog Server, which enables devices within the site to send logs to you syslog Server.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Dpj,
    Zyxel Melen
Nebula Tips & Tricks
