WLAN for WIFI7 with activated MLO without better performance
iTom
iTom Posts: 2 image  Freshman Member
I tested my Laptop with Intel® Killer™ Wi-Fi 7 BE1750x PC network chip on both plan networks with activated MLO and without and I recognized no speed difference, this shouldn't be? What was my mistake? Thanks for help!
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,611 image  Zyxel Employee
    Hi @iTom,
    Could your share your SSID setting (with MLO) and the client Wi-Fi connection info? Please dump the client Wi-Fi connection info via cmd with command "netsh wlan show interface" (Windows cmd). Thanks!
    Zyxel Melen
  • Zyxel_Melen
    Update:
    Our Wi-Fi 7 AP are all STR MLMR. However, most of Wi-Fi 7 end devices are support only 1 radio. Therefore, we get the result that there is no difference between MLO enabled and disabled.
    Zyxel Melen
Nebula Tips & Tricks
