No internet with NWA50AX PRO
perl0n
perl0n Posts: 1  Freshman Member
For the past two days, my NWA50AX PRO access point has not allowed me to access the Internet.
My client are connected, they have an IP address, but no Internet access.
I can see my client clearly from the nebula interface, and the ping and trace tests are OK.
I've installed the latest firmware.
Any ideas ?
Thank you
    PeterUK Posts: 3,993  Guru Member
    edited June 18
    seems odd that ping and trace going past your router shows fine? can you do ping and trace from a PC fine?
    maybe its DNS? can you try nslookup zyxel.com
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,714  Zyxel Employee
    Hi @perl0n,
    This could be because your client doesn't has DNS server setting. Please check your firewall DHCP configuration if it have DNS server setting. If it has set DNS server, please help to change to 8.8.8.8 or 1.1.1.1. If not, please set DNS server setting like 8.8.8.8 or 1.1.1.1.
    Zyxel Melen
