XMG1930-30 - Access L3 License - Flow Control
mjr
mjr Posts: 31 image  Freshman Member
First Comment Friend Collector Seventh Anniversary
Hello!
On my site are 4x XMG1930-30 and 1x XS3800-28.
I want to test "flow control" on a XMG1930-30, so I bought a
LIC-ACSL3, Access L3 License for XMG1930-30
the activation was ok, the switch shows the license (after the reboot).
The site has no "Nebula Pro Pack". (status inactive)
Problem:
How can I activate "flow control" on a port?
In Nebula there is no option for "flow control" and in the web GUI there is also no option for "flow control".
Do I have to assign a license to every XMG1930-30 and the XS3800-28 or only to that switch where I will use "flow control"?
Thank you for your support.
mjr
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,047 image  Zyxel Employee
    Hi @mjr,
    You don't need other license. This is because XMG1930 port setting option on Nebula desn't have flow control. Please access your device via SSH and configure it with CLI.
    Here is the command:
    #configure
    (configure)# interface port-channel XX
    (config-interface)# flow-control
    (config-interface)# exit
    (configure)# exit
    #write memory
    Zyxel Melen
  • mjr
    1. XMG1930-30 with "Access L3 license" supports CLI configuration.
    2. Without "Access L3 license", you can SSH to XMG1930, but you can't use CLI configuration. Only support to show device information, like "show system", "show running-config", etc.
  • Zyxel_Melen
    Hi @mjr,
    #configure
    (configure)# exit
    #write memory
    Zyxel Melen
  • mjr
Service & License Help Center
