Email from not accepted
PeterUK
PeterUK Posts: 3,893  Guru Member
edited June 13 in USG FLEX H Series
FLEX200H V1.32(ABWV.0)ITS_719_20250606
Email Daily Report
then I tried admin@zyxel-router.ddns.net
and that worked but then could not change it any more went to Notification and changed
Send From to admin@zyxel-router7.ddns.net
and it accepted went back to Email Daily Report and it shows this
Best Answers
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    Hi @PeterUK ,
    I was unable to reproduce the issue you reported using the same firmware version and email address.
    However, when testing, we noticed that if there's a space after the email address, the message appears as you described.
    Could you please double-check whether there was any space before or after the email address when you entered it?
    Zyxel_Judy
    Hmm I have rebooted to see if the problem returns and it didn't.
    one thing to note is valid character does not show [0-9]
  • Zyxel_Judy
    Hi @PeterUK ,
    Thank you for the reminder.
    We will add numbers as accepted characters for email addresses in the notes for future firmware versions.
    Zyxel_Judy
    edited June 20
    Ok so I when to 132ABWV0ITS-25WK18-0606-250400363 back to V1.32(ABWV.0)ITS_719_20250606 and the problem has come back when I put in
    in Email Daily Report Emal from I get It cannot exceed 83 characters. The valid characters are [a-z][A-Z][/=?^_.{|}~w-!#$%*+].
    Would you like to log in and check this?
  • Zyxel_Judy
    Hi @PeterUK ,
    We accessed your 200H and confirmed that the FW version is V1.32(ABWV.0)ITS_719_20250606. There is no alert for "Email from" when typing admin@zyxel-router7.ddns.net, as shown in this image.
    Zyxel_Judy
    hi Judy
    You need to click apply with that Email
  • Zyxel_Judy
    Hi @PeterUK ,
    Please try the solution (WK25 FW) we shared with you via private message to see if the issue is resolved.
    Note: There is no issue with the 1.32 FCS version.
    Zyxel_Judy
    Ok see you change the Email then changed it back to .net and changed between firmware's seem good now thanks.
    edited July 14
    Nope problem is back it shows
    put in the Email and apply reload the page shows the same thing
    odd thing is I'm still getting Daily Report sent
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,529  Zyxel Employee
    This could be due to the side effects of the firmware with the date code you are running. Please be assured that this issue will be fixed in version 1.35.
    Zyxel Melen
