Zyxel 500H – Help Setting Up Internet Failover
Darkn3ss
Darkn3ss Posts: 5  Freshman Member
I have a Zyxel 500H firewall. Today, a second backup internet line was activated, and I would like to enable failover mode. However, I can't find any guides on how to configure this feature on the firewall.
Could you help me with the setup?
Thank you!
    PeterUK Posts: 3,983  Guru Member
    You can setup a trunk where one if active and one is passive in network > interface > trunk tab add new trunk then set as User-Defined Trunk. I'm not too sure how this works and may need your active WAN to have a WAN IP and checks by ARP to your ISP gateway to Failover.
    But possible with that if you don't get the WAN IP or your ISP WAN gateway is up but internet has failed means it will not Failover
    so another way is by setting up routing rules with Connectivity Check
    rule 1
    incoming any or given LAN
    next hop WAN1
    Connectivity Check to some where
    rule 2
    next hop WAN2
  • Darkn3ss
    Which option should I choose out of the three?
    edited June 19
    For active and passive it be weighted round robin
    After some testing for the active and passive trunk to work the WAN1 active you need to set Connectivity Check in interface WAN1 for it to Failover.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,697  Zyxel Employee
    If me, I will change the default WAN trunk to the profile you create.
    Zyxel Melen
  • Darkn3ss
    What should I set to "parameter?". What does it represent?
    The parameter in your case is not important with your setup. For passive to switch from active you will also need to go to ge1 WAN1 interface settings and enable Connectivity Check.
  • Zyxel_Melen
    You can keep it as 1. The parameter is what Weighted Round Robin to balance the traffic load between interfaces based. For example, if you have WAN 1 and 2 as active interfcae and WAN 1 parameter is 2, WAN 2 is 1. The WAN 1 will have more traffic, WAN 1 for 2 session's traffic and WAN 2 for 1 session's traffic in each round of 3 new settions.
    Here is the definition:
    This field displays with the weighted round robin load balancing algorithm. Specify the weight (1~10) for the interface. The weights of the different member interfaces form a ratio. This ratio determines how much traffic the Zyxel Device assigns to each member interface. The higher an interface’s weight is (relative to the weights of the interfaces), the more sessions that interface should handle.
    Zyxel Melen
