I would like to get visio stentles for zyxel switchs
Hi @Denis2025
We currently only provide product icons in PNG format.
The information you provided is not from the Zyxel official website, nor from the unit we cooperate with. By the way, the image in the link you shared only shows the product icon in PNG format, not as a VSS file.
To obtain accurate information about Zyxel products, we recommend using:
Zyxel download libraryZyxel_Judy
Hi @Denis2025 ,
You can get Visio stencils for the switch by following these steps:
- Go to the Zyxel download library
- Type the switch model name in the search
- Click on the Product icon
- Download the Visio stencils from the available files
Zyxel_Judy
You're joke, these are png files, not vvs.
I read the articles like this:
ZyXEL makes preparing network projects even easier!ZyXEL announces an expansion of the scope of support provided to technical specialists. Now at your service is a library of network elements (stencils), made in Microsoft Visio format and containing schematic images of almost the entire range of equipment manufactured by the company - from carrier-class devices, IP DSLAM and Ethernet switches, to Internet centers, DSL and analog modems and even some discontinued products. In total, the set includes more than 100 templates, combined into 13 groups corresponding to different types of users and telecom operators working with the company's products will be able to use the ZyXEL library of network elements for the Microsoft Visio package when documenting networks….
Where to get vvs files ?
Hi @Denis2025 ,
Could you share the link to the article you mentioned so we can help to verify the accuracy of the information?
Zyxel_Judy
Hi @Denis2025
- 603 USG FLEX H Series
- 481 News and Release
