I would like to get visio stentles for zyxel switchs
Denis2025
Denis2025 Posts: 4 image  Freshman Member
I would like to get visio stentles for GS series.
Specifically GS1900-24HP and XGS2210-28hp
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    edited June 25 Answer ✓
    Hi @Denis2025
    We currently only provide product icons in PNG format.
    The information you provided is not from the Zyxel official website, nor from the unit we cooperate with. By the way, the image in the link you shared only shows the product icon in PNG format, not as a VSS file.
    To obtain accurate information about Zyxel products, we recommend using:
    Zyxel download library
    Zyxel_Judy
    Untitled Image
