USG LITE 60AX - FEATURES
FelippeSic
FelippeSic Posts: 5 image  Freshman Member
edited June 19 in Nebula
We are currently evaluating the USG LITE 60AX for deployment in one of our customer environments and would like to clarify a specific technical feature.
We have verified that models in the USG FLEX and USG FLEX H series include support for the "External Block List" (EBL) feature, which allows the appliance to ingest external IP address lists for dynamic blocking purposes.
  • Domain Names with Wildcards: e.g., *.example.com
  • Full URL Path and Host Name: e.g., http://example.com/path
  • HTTP and HTTPS URLs: e.g., https://example.com
Could you please confirm whether the USG LITE 60AX also supports this functionality?
If this feature is not currently available on the USG LITE 60AX, we would like to know if there are any plans in the product roadmap to implement it in future firmware releases.
This information is crucial for ensuring compatibility with the customer’s existing security policies.
We look forward to your response.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hi @FelippeSic ,
    Currently, the "External Block List" (EBL) feature is not available on the USG LITE 60AX. However, we recognize the potential value this feature would provide to users and will evaluate this carefully.
    Thank you for using Zyxel products and services.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @FelippeSic ,
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
