Change certificate of a managed AP?
Tzunami
Tzunami Posts: 32 image  Freshman Member
Is it possible to add a new certificate to a AP (WAX650S) managed by a USGFlex200?
When I'm connecting direct to the AP, I will get a “not secure” message of the browser. I have added the cert and give the rights, but the browser says:
This server could not prove that it is 192.168.xxx.xxx. Its security certificate is from wax650s_xxxxxxxxxxx. Possible reasons include a misconfiguration or an attacker intercepting your connection.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,632 image  Zyxel Employee
    Hi @Tzunami,
    AP controller, USG FLEX series, doesn't support to import certificate to AP. Additionally, AP doesn't support importing the certificate for HTTPS.
    May I know why you need to access AP once it is under controller mode? Because under this mode, AP isn't accessible. Please configure and monitor your AP on AP controller.
    Zyxel Melen
  • Tzunami
    edited June 2025
    Did you know the answer: Because I can! 😉. Not a special intension, but you can upload scripts directly, for example. Is a cert change also not possible over FTP or SSH?
    If I get a screen like this, I would say, it is accessible under this mode.
    Bildschirmfoto 2025-06-07 um 16.42.03.png Bildschirmfoto 2025-06-07 um 16.32.42.png
  • Tzunami
  • Zyxel_Melen
    Hi @Tzunami,
    I checked, but we don't know what script can do this. Could you share the script with us? Unsure if this is usable or not. In addition, when AP is controlled by APC, currently isn't supported to update the device certificate, which is also not needed since you won't manage the AP via its web GUI.
    Zyxel Melen
