Email from not accepted
FLEX200H V1.32(ABWV.0)ITS_719_20250606
Email Daily Report
then I tried admin@zyxel-router.ddns.net
and that worked but then could not change it any more went to Notification and changed Send From to admin@zyxel-router7.ddns.net
and it accepted went back to Email Daily Report and it shows this
Best Answers
Hi @PeterUK ,
Please try the solution (WK25 FW) we shared with you via private message to see if the issue is resolved.
Note: There is no issue with the 1.32 FCS version.
Zyxel_Judy
This could be due to the side effects of the firmware with the date code you are running. Please be assured that this issue will be fixed in version 1.35.
Zyxel Melen0
Hi @PeterUK ,
I was unable to reproduce the issue you reported using the same firmware version and email address.
However, when testing, we noticed that if there's a space after the email address, the message appears as you described.
Could you please double-check whether there was any space before or after the email address when you entered it?Zyxel_Judy
Hmm I have rebooted to see if the problem returns and it didn't.
one thing to note is valid character does not show [0-9]
Hi @PeterUK ,
Thank you for the reminder.
We will add numbers as accepted characters for email addresses in the notes for future firmware versions.
Zyxel_Judy
Ok so I when to 132ABWV0ITS-25WK18-0606-250400363 back to V1.32(ABWV.0)ITS_719_20250606 and the problem has come back when I put in
in Email Daily Report Emal from I get It cannot exceed 83 characters. The valid characters are [a-z][A-Z][/=?^_.{|}~w-!#$%*+].
Would you like to log in and check this?
Hi @PeterUK ,
We accessed your 200H and confirmed that the FW version is V1.32(ABWV.0)ITS_719_20250606. There is no alert for "Email from" when typing admin@zyxel-router7.ddns.net, as shown in this image.
Zyxel_Judy
Hi @PeterUK ,
Zyxel_Judy
Ok see you change the Email then changed it back to .net and changed between firmware's seem good now thanks.
Nope problem is back it shows
put in the Email and apply reload the page shows the same thing
odd thing is I'm still getting Daily Report sent
Zyxel Melen0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
