USG 310 IPv6
from ISP provider we got range ipv6 address 2a03:a820:500:100::/56.
2a03:a820:500:1ff::/64 is used as a junction network where USG 310 has IPv6 address 2a03:a820:500:1ff::2, ISP provider router 2a03:a820:500:1ff::1.
I used this manual to set up the USG 310
WAN interface:
Enable IPv6.
IPv6 Address / Prefix Lenght: 2a03:a820:500:1ff::2/64
Gasteway: 2a03:a820:500:1ff::1
Matric: 0
LAN interface :
Enable IPv6
Enable Router Advertisement
Advertised Prefix Table 2a03:a820:500:101::/64
PC Client (ipconfig /all)
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel 21140-Based PCI Fast Ethernet Adapter (Emulated)
Physical Address. . . . . . . . . : 00-15-5D-01-06-08
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IPv6 Address. . . . . . . . . . . : 2a03:a820:500:101:15f6:5a43:b5b0:609c(Preferred)
Temporary IPv6 Address. . . . . . : 2a03:a820:500:101:65:7550:f617:8207(Preferred)
Link-local IPv6 Address . . . . . : fe80::15f6:5a43:b5b0:609c%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.2.21(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.248.0
Lease Obtained. . . . . . . . . . :12.5. 2019 15:32:55
Lease Expires . . . . . . . . . . : 14.5. 2019 16:32:57
Default Gateway . . . . . . . . . : fe80::be99:11ff:feb8:9e18%14
192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.2
DHCPv6 IAID . . . . . . . . . . . : 234886493
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-23-9A-9F-A4-00-15-5D-01-06-08
DNS Servers . . . . . . . . . . . : 192.168.1.2
Primary WINS Server . . . . . . . : 192.168.1.2
NetBIOS over Tcpip. . . . . . . . : Enabled
From USG 310 to IPv6 address google server ping OK.
From the PC to IPv6 address google server ping FAILED.
From PC to Link-Local Address LAN interface ping FAILED.
Where can the error be in the USG 310 setup?
Paul
Paul
Assign a static IPv6 IP for your LAN interface.
I set a static IPv6 for my LAN interface.
2a03:a820:500:101::1/64
From PC to 2a03:a820:500:101::1 ping FAILED.
From PC to 2a03:a820:500:101::1 ping OK. (fixed FW rule on USG 310)
From PC to Link-Local Address LAN interface ping OK. (fixed FW rule on USG 310)
but still
Could you check if you check the "Enable Stateless Address Auto-configuration" setting on LAN interface ?
This option should be off.
And can you ping the ISP router 2a03:a820:500:1ff::1 ?
From the PC to IPv6 address google server ping OK.
I had to restart the PC client.
Thank you.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
