Multiple licenses added to Nebula ORG - difficult to manage them quickly
GiuseppeR
GiuseppeR Posts: 664 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
Hello everyone,
I asked my vendor to align the expiration date of my Nebula products portfolio (for a single specific ORG that I manage) to end in december 2026.
I thought it would give me an easy way to install a license inside Nebula to do that.
In reality I had to buy 63 different licenses to try to do that alignment for expiring date in december 2026:
As you can see I have to import and to sort 47+12+3+1 different licenses assigning them to each single device.
Do you plan to use a quick way to do that?
Have a nice day 😎
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Zyxel Employee
    Hi @GiuseppeR ,
    Currently, you can choose all licenses for the same device and then implement the license assignment process, which includes setting the target expiration date and specifying which device the licenses belong to, using the steps below:
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Hi @GiuseppeR ,
    Zyxel_Judy
    Untitled Image
  • GiuseppeR
    Hello @Zyxel_Judy
    that is great, I did not see that option as "target date".
    I assigned them selecting each device and adding to it the correct amount of licenses (month/year) based on Nebula estimated end date.
    Next ORG I'll organize it and try your option
Nebula Tips & Tricks
