Nat rule creation issue on our 500H
Mk88_it
Mk88_it Posts: 76 image  Ally Member
edited June 2025 in USG FLEX H Series
Firmware: V1.32(ABZH.0)ITS-0423-250300903
I'm here again... I don't wkonw what excactly is going on our 500H, and sincerly I don't have the time to waste on this....but…
This is the third NAT rule I created that freezed the device and I had to reboot it
To summarize
action made: Create a new NAT rule
What happened after:
Log setting section broken, display "page loading"
Lost connectivity from some vlans
DHCP not working on some vlans
Tried to Switching to secondary device HA with same symptoms
Tried to collect the logs from the gui, aborted after a lot waiting time (more of 10 mins)
Tried to collect the logs from ssh, same as from gui
  • Zyxel_Tina
    Zyxel_Tina Posts: 691 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    For users encountering a similar issue, here is a summary of our findings and a suggested workaround:
    Symptom
    When modifying the NAT rule, certain VLANs are unable to access the internet.
    Root Cause
    1. ARP entry disappears after NAT rule change
      After a NAT rule is modified, we observed that the ARP entry disappears from the firewall. This causes return packets to fail, leading to interrupted connectivity.
    2. Special ISP configuration: PPP bind /32 with a different gateway subnet
      Upon further inspection, we found that the WAN interface is using a /32 PPPoE IP address with a gateway outside of the same subnet. This setup is common with some Italian ISPs, and may require specific handling.
    In such scenarios, we’ve seen unexpected behaviors — such as HA being affected, or the issue only appearing after NAT changes. These are likely due to the current firmware not fully supporting this kind of routing setup. A feature request addressing this was previously submitted, and it may be included in future release. Please kindly follow our Security Gateway News and Release to stay updated on the latest information.
    Workaround
    To ensure return traffic is properly routed, we recommend manually adding the WAN secondary IPs.
    Zyxel Tina
  • Zyxel_Tina
    Hi @Mk88_it,
    Could you please provide us with your current configuration and the third NAT rule you intend to apply?
    We'll contact you through private message.
    Zyxel Tina
  • Zyxel_Tina
    Symptom
    Root Cause
    Workaround
    Zyxel Tina
