NWA50 won't connect via https
All brands have this problem when you first set them up its just not possible to put a valid certificate from the start like name a web site with a IP you go to by IP with a valid certificate….there are none! this is just the way it is.
like I said you can make it valid after you log in to make a self sign certificate by IP
you can can even give it a domain name if you have DNS point to it or even a non self sign certificate.
- 601 USG FLEX H Series
- 480 News and Release
