VPN issue - Impossible to edit SHA1 to SHA256
Hello everyone,
when you go here to create a VPN on prem:
You cannot edit Authentication SHA1 to SHA256 :
and save it because it reverts back to SHA1.
Same thing with Proposal:
You have to add a new line with SHA256 and delete the old one with SHA1, like this:
Hi @GiuseppeR,
We will address the issue and release the updated firmware in the next weekly update.
For now, we suggest that you click the green tick after editing and then click Apply.
Thanks.
Ivan
When you change the Authentication SHA1 to SHA256 you must click the tick button (on the right) then click apply
Hello @GiuseppeR,
Based on your description, I guess after you chose SHA256, you didn't click the tick on the right-hand side and click Apply in the lower right corner?
If so, I suggest you click the green tick on the right-hand side before clicking Apply.
Please share feedback from you.
Thanks.
Ivan
Hello @Zyxel_Ivan
you are right.
My scenario was like this:
But I thought that the 1 "blu arrow" was not needed when clicking 2 "orange arrow".
I did not considered it, seeing the Green button with "Apply".
Hi @GiuseppeR,
Thanks.
Ivan
Hi @Zyxel_Ivan
thanks for your feedback, have a great day 😎
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
