VPN issue - Impossible to edit SHA1 to SHA256
GiuseppeR
GiuseppeR Posts: 431  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
when you go here to create a VPN on prem:
You cannot edit Authentication SHA1 to SHA256 :
and save it because it reverts back to SHA1.
Same thing with Proposal:
You have to add a new line with SHA256 and delete the old one with SHA1, like this:
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 375  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Hi @GiuseppeR,
    We will address the issue and release the updated firmware in the next weekly update.
    For now, we suggest that you click the green tick after editing and then click Apply.
    Thanks.
    Ivan
    PeterUK Posts: 3,893  Guru Member
    edited June 27
    When you change the Authentication SHA1 to SHA256 you must click the tick button (on the right) then click apply
  • Zyxel_Ivan
    Hello @GiuseppeR,
    Based on your description, I guess after you chose SHA256, you didn't click the tick on the right-hand side and click Apply in the lower right corner?
    If so, I suggest you click the green tick on the right-hand side before clicking Apply.
    Please share feedback from you.
    Thanks.
    Ivan
  • GiuseppeR
    Hello @Zyxel_Ivan
    you are right.
    My scenario was like this:
    But I thought that the 1 "blu arrow" was not needed when clicking 2 "orange arrow".
    I did not considered it, seeing the Green button with "Apply".
  • Zyxel_Ivan
    Hi @GiuseppeR,
    Thanks for the reply.
    Let me check with the team and get back to you.
    Thanks.
    Ivan
  • Zyxel_Ivan
    Hi @GiuseppeR,
    Thanks.
    Ivan
  • GiuseppeR
    Hi @Zyxel_Ivan
    thanks for your feedback, have a great day 😎
