Suitable repeaters for Nebula FWA510
Hille
Hille Posts: 3 image  Freshman Member
edited May 2025 in Nebula
A new question about suitable repeaters. According to the manual and what I've read here at Community, the Nebula FWA510 lacks support for Easymesh. I need a repeater with two Ethernet ports for connecting devices and another to amplify my wifi outdoors. I can't find anything on the Swedish market that I can see obviously working with the Nebula FWA510. What should I choose?
Best Answers
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    Hi @Hille ,
    The Nebula FWA510 doesn't support Easymesh, but we can recommend the best suitable network topology with Zyxel device as below:
    • Connect either the WAC500H or WAX300H to your Nebula FWA510 using an Ethernet cable. Both these models feature multiple LAN ports for your wired connections.
    • For outdoor coverage, the NWA55AXE can wirelessly connect to either the WAC500H or WAX300H using the smart mesh technology, eliminating the need for additional cabling to your outdoor areas.
    Zyxel_Judy
    Untitled Image
  • Zyxel_Tina
    Zyxel_Tina Posts: 676 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @Pulla,
    Sorry for the late reply!
    Since the FWA510 does not support the mesh feature, a wired connection to the downlink AP is required, as illustrated in the topology shown in Judy’s previous reply. In other words, the FWA510 cannot connect wirelessly to any repeater or extender devices.
    Zyxel Tina
  • Zyxel_Judy
    Hi @Hille ,
    Zyxel_Judy
    Untitled Image
  • Pulla
    Pulla Posts: 2 image  Freshman Member
    Is there repeater/extender that works wirelessly with FWE510. Ethernet ports are not must in thia case.
    WX3100-T0 perhaps?
  • Zyxel_Tina
    Hi @Pulla,
    Zyxel Tina
    PeterUK Posts: 4,415 image  Guru Member
    I think this would work
    WX3100-T0 | Dual-Band Wireless AX1800 Gigabit Access Point/Extender | Zyxel Networks
    WDS is not supported on FWA510 but a AP that can connect as a client to FWA510 should work
Nebula Tips & Tricks
