NWA1123-AC: What's username/password?
sakuragaoka
sakuragaoka Posts: 3 image  Freshman Member
edited May 2024 in Wireless
I have a NWA1123-AC with firmware version V2.12(AAOX.0). I backed up my config, but after reloading it my personal username and password don't work anymore. Neither do the default credentials, as in admin/1234. What's going on? They only way out it seems is by resetting the device, but that's defeating the purpose of being able to back up the config. What can I do?
  • sakuragaoka
    It seems to be a problem with the type of browser I'm using. With the Internet Explorer everything works just fine, above problem occured only when using Google Chrome.
  • Winnie
    Winnie Posts: 30 image  Freshman Member
    Hi @sakuragaoka
    Have you try to clear Google Chrome's cookies?
  • sakuragaoka
    Thank you for your suggestion which makes a lot of sense indeed. I haven't tried it out (yet) though, because it worked with IE, and also because I usually hesitate to clear my cookie cache. Thanks again.
  • livealive
    livealive Posts: 23 image  Freshman Member
    Or try to use the seamless window(incognito window mode)of Google Chrome to access AP's GUI with your personal username and password, it should also be solved this situation.
