ATP200, SFP to Lan Port?
Hi
My Home Server is hooked directly to the SFP Port on my ATP. The ATP is the DHCP Server for a bunch of Virtual Machines. Now I have to move them somehow to an Server who is connect lets say Lan Port 1 (= P4). For that reason I set up LAN2 and under "DHCP Setting" I choose DHCP Relay and in "Relay Server 1" I put in the IP from the SFP DHCP like 192.168.100.1
When I activate the Rule the hole System drive insane and not asign any IP Adress to any network anymore.
So what is the correct way?
May I know your DHCP server is based on which OS? Linux or Windows Server?
Zyxel Melen1 -
It is the DHCP Server from sfp Port.
Hi
Sorry for the late replay I try to ex plane it again.
Here is how the SFP Port config: It is "just" the DHCP Server actived.Here on Picture 2 is the Lan2 who I can config to be on the Physical Lan Ports.
Do I need to set "DHCP Relay" that for example when I put LAN 2 on Port 7 that a Pc who is pluged into Port 7 get a IP Adress from the "SFP" DHCP Server Pool?
Thanks0 -
The SFP can not port role with LAN2
LAN2 can only port role with other ethernets
To expand the SFP network you will need a switch to it
Does "DHCP Relay" not work in that case?
Can't say I used DHCP Relay but I don't think it will do what you want. My understanding is there is DHCP server by Zywall for its LAN but if on another subnet you have a 3rd party DHCP server that will manage that subnet that where DHCP Relay comes in.
Yes, USG FLEX doesn't support receiving DHCP relay packets, therefore, you will need a switch for your scenario. SFP port and other ethernet ports can't combine together or the LAN interface set DHCP relay to SFP port as DHCP server. One is because it does not support receiving DHCP relay packets, another is because the IP subnet overlaps on different interfaces.
Zyxel Melen0 -
I use an ATP 200. Thanks
Create an internal type bridge interface and add both lan2 & sfp interface as member.
This can group ports of two interfaces like a virtual software switch.
The only drawback is the traffic between ports is not wire speed as a hardware switch.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
