Using Zyxel SCR 50AXE as the secondary router for Bridged Connection
We're trying to set up the Zyxel SCR 50AXE as a secondary router for a connection currently using a BT Smart Hub 2. We would like the BT router to act as the Bridge.
When the BT router is in bridge mode, no configuration options we try on the Zyxel seem to give it an internet connection.
We have tried DHCP, Static with the Gateway looking at the BT router, PPPoE for the actual BT connection.
The only reason we need the BT Router is because the Zyxel doesn't have ADSL Connection. It's very hard troubleshooting as the router has to be connected to the Nebula Cloud to make any changes and then these changes take a few minutes each to propegate.
Any advice?
How about connect to local GUI(LAN gateway IP) to re-config your WAN interface.
Bonjour,
Je n'arrive pas à accéder à l'interface local du scr50axe ni en wifi ni par le port lan ?
Un conseil ?
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
