SSLVPN Issue HA
2»
  • Fred_77
    Fred_77 Posts: 147 image  Ally Member
    5 Answers First Comment Friend Collector Fifth Anniversary
    Hi @Zyxel_Melen
    Flex500H updated WK25; remote access enabled.
    Regards
    Lorenzo
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,623 image  Zyxel Employee
    Hi @Fred_77,
    Thanks for the remote. After our investigation and replicate, we found that one of the TCP [PSH, ACK] was missing and caused the SSLVPN tunnel can't connect.
    However, in our replicate, we didn't encounter this issue with the same configuration as yours.
    Therefore, we need your help to set a test scenario so we can remotely replicate and investigate. I will send the detailed information to you via the previous private message.
    Zyxel Melen
  • Fred_77
    Hi @Zyxel_Melen
    Update 3….
    after fw upgrade to WK25 a laptop connected "on" the wan interface can connect.
    But no connection from outside is possible. (tested with different devices and different connectivity)
    This would lead one to think of an isp related problem.
    But then why you can connect?
    In PM user and pwd of the laptop connected.
    Regards
    Lorenzo
  • Zyxel_Melen
    Update:
    After checking with this test scenario, we confirmed this is more likely because ISP dropped the [SYN, ACK] packet.
    Zyxel Melen
