fail over wan
Dpj
Dpj Posts: 209 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
Hmm, i discover now fail over wan isn't available for flex 50h?
When will it available (in nebula)
Yours Dennis
  • Dpj
    is there a way to check through the API the connectivity of the second wan connection? Like an ping through this specific port or something like that.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,394 image  Zyxel Employee
    Hi @Dpj
    USG FLEX 50H supports wan fail over, you will need to set it in the interface trunk function. You may access the device's local GUI to set it.
    https://jam.dev/c/22a29032-3671-426a-92ea-c7f791cc8184
    Nebula currently not support the interface trunk function. It is in our feature list, but the schedule is TBD.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Dpj
    May I know this request is to use API to set connectitivty check or triger a ping test?
    Zyxel Melen
  • Dpj
    I realy hope in the future it will be possible to edit more settings through the API. Just for example Create Security Policies, Nat Rules, Set Fail over Wan. etc. (but set an connectivity check would also be nice). At this moment it's more asking to nebula what do you have for me instead of creating / changing settings. But to come back to your question, it was now to ping through an specific interface.
    Today i got the question: For example, we find an issue with our used configuration, and we have lik 300 customers. with all the same hardware. (just example). How can we push new settings to all customers, instead of going through all the customers one by one.
    For that the API would be great. But for now the only posibility i think is to go one by one through all the customers.
  • Zyxel_Melen
    Hi @Dpj
    Nebula API for ping currently not support to select specific interface. We have created an idea post for this requirement.
    Nebula open API support ping option for specific interface — Zyxel Community
    Development is in progress for the set/configure API. Thank you for your patience as we make progress. Stay tuned for more updates soon!
    Zyxel Melen
Nebula Tips & Tricks
