Zyxel flex 50 - VPN Mac Sequoia 15.5
faye83
faye83 Posts: 8 image  Freshman Member
Hi all
can anyone help me with a guide to configure the VPN part, the clients to connect are Mac.
Thanks for your support
Regards
Faye
  • Zyxel_Tina
    Zyxel_Tina Posts: 339 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 50 Answers First Comment
    Hi @faye83,
    We suggest using the following configuration for IKEv2 VPN between your device and macOS clients:
    • Phase 1: AES256, SHA256, DH19
    • Phase 2: AES256, SHA256, PFS: None
    For detailed configuration and verification instructions, please refer to this article.
    Zyxel Tina
  • Zyxel_Tina
    Hi @faye83,
    Zyxel Tina
