Replace ATP200 with Flex200H
TAPTech
TAPTech Posts: 174 image  Master Member
First Comment Friend Collector Seventh Anniversary Nebula Gratitude
If I replace my Nebula ATP200 firewall with a Flex 200H, will it copy the settings over, or will I need to start from scratch?
  • Zyxel_Tina
    Zyxel_Tina Posts: 707 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @TAPTech,
    Unfortunately, because your ATP200 and USG Flex 200H are managed by Nebula, direct configuration migration using a converter tool is not supported for this specific scenario. You will need to manually reconfigure the settings on your USG Flex 200H. Thank you for your understanding.
    Zyxel Tina
  • MCFH
    MCFH Posts: 19 image  Freshman Member
    First Comment Friend Collector Eighth Anniversary
    Check the conversion tool
  • TAPTech
    Thank you for the tip. I checked the conversion tool, however both of the Firewalls are on Nebula. It looks like the conversion tool is only for local/non-cloud.
  • Zyxel_Tina
    Hi @TAPTech,
    Zyxel Tina
  • TAPTech
    Hi Tina,
    Here is how I made it a bit easy- created a new Site in Nebula with the USGFlex200H and copied over the settings. Once the settings were complete, I move the switches and access points to the new site, then deleted the old site.
