ZyWall 110 Tunnel [L2TP_VPN] Phase 2 Local policy mismatch
Vyacheslav
info | IKE | ISAKMP SA [L2TP_VPN_GW] is disconnected | | ||||
info | IKE | Received delete notification | | ||||
info | IKE | Recv:[HASH][DEL] | | ||||
info | IKE | Send:[HASH][NOTIFY:NO_PROPOSAL_CHOSEN] | | ||||
info | IKE | [SA] : No proposal chosen | | ||||
info | IKE | [ID] : Tunnel [L2TP_VPN] Phase 2 Local policy mismatch | | ||||
info | IKE | Recv:[HASH][SA][NONCE][ID][ID] | |||||
info | IKE | Рhase 1 IKE SA process done Phase 1 and Phase 2 Proposal settings are the same. |
Hi @Vyacheslav
The VPN phase 2 is configuration of VPN Connection.
You can make sure if your configuration is correct.
Thanks for the answer, but my settings are the same as yours except 3DES, which is missing from me on ZyWall 110 (firmware 4.33).0
May be downgrade firmware to 4.25?0
from 4.33 realase
IPSec VPN1. [SPR: 070814168][Symptom]VPN tunnel could not be established when:a. a non ZyWALL/USG peer gateway reboot andb. ZyWALL/USG has a previous established Phase 1 with peer gateway, and the Phase 1 has not expired yet. Under those conditions, ZyWALL/USG will continue to use the previous phase 1 SA to negotiate the Phase 2 SA. It would result in phase 2 negotiation to fail.[Workaround]User could disable and re-enable phase 1 rule in ZyWALL/USG or turn on DPD function to resolve problem.
its my situation, but me that dont help.0 -
Thank you all! The problem was that as a test computer I used a home with Windows 10, and VPN started working after "regedit"==> "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\PolicyAgent"==>parameter "AssumeUDPEncapsulationContextOnSendRule" "Value Data" it was changed from "2" on "1". I express special thanks to the user "[Zyxel] jonatan" for actively participating in solving my problem.
Hi @Vyacheslav
The registry key 2 you mentioned is for establish VPN when both USG and client are behind NAT router. In your scenario, USG should not behind NAT, the value 1 is enough.
It’s good to hard you resolved the issue.
- 588 USG FLEX H Series
- 476 News and Release
