Measuring cellular signal FWA510
Dr_Elmer
Dr_Elmer Posts: 11 image  Freshman Member
I have some issues with losing connection to the cellular network with my FWA510. According to the Nebula app the cellular signal is -97 dbm.
I will try to install an external antenna, but I wonder if I can get more info about the cellular network from the app? Is it using the 4G or 5G network for example.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,631 image  Zyxel Employee
    Hi @Dr_Elmer
    Nebula Mobile APP doesn't support displaying further cellular information currently.
    To check the detailed cellular information, you may use:
    1. Nebula control center > Mobile router Live tools Cellular info.
    2. Download Zyxel Air to check the device info locally.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Dr_Elmer
    Zyxel Melen
Nebula Tips & Tricks
