AX7501-B1 wildcard dns entries
g1raffi
g1raffi Posts: 1  Freshman Member
Hi guys,
I have a AX7501-B1 router at home, and I'm kind of confused about DNS entries within the home-network. The user-guide documentation of the router states that wildcard dns entries should be possible if "the leftmost character is an asteriks (*)". But the configuration simply won't allow me to add a wildcard entry in the web GUI.
Did I misread the user guide (https://spdl.zyxel.com/AX7501-B1/user_guide/AX7501-B1_AX-DX-EX-PX%20Opal%20WiFi6%20Series%20UG_V5.17-5.70_Ed20.pdf) in section "Table 123 Network Setting > DNS > DNS Entry: Add or Edit" or is this a bug?
Thanks in advance
  • bahecz44120
    bahecz44120 Posts: 100  Ally Member
    First Comment First Answer
    I would suggest you to check with ISP to see if there is latest fw to update. Then, try to set DNS wildcard again. Hope this helps.
