API
Dpj
Dpj Posts: 213 image  Master Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
edited July 2025 in Nebula
Another question about API. I really hope this is not correct. But is it true that i cannot read the eventlog from an flex 50h through the API?
that would be very disapointing. It means we almost cannot create tickets of those firewalls in our system.
If it's not possible yet, when will it be available do you think?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,584 image  Zyxel Employee
    Hi @Dpj
    This is because this API for H series is not supported now. The current ETA is the same as creating organization API "at the end of Q3". If the API is available sooner, I will let you know.
    Zyxel Melen
Nebula Tips & Tricks
