ZyWall 110 Tunnel [L2TP_VPN] Phase 2 Local policy mismatch
Vyacheslav
Vyacheslav Posts: 17  Freshman Member
edited April 2021 in Security
info
IKE
ISAKMP SA [L2TP_VPN_GW] is disconnected
info
IKE
Received delete notification
info
IKE
Recv:[HASH][DEL]
info
IKE
Send:[HASH][NOTIFY:NO_PROPOSAL_CHOSEN]
info
IKE
[SA] : No proposal chosen
info
IKE
[ID] : Tunnel [L2TP_VPN] Phase 2 Local policy mismatch
info
IKE
Recv:[HASH][SA][NONCE][ID][ID]
info
IKE
Рhase 1 IKE SA process done
Phase 1 and Phase 2 Proposal settings are the same.
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,386  Zyxel Employee
    100 Answers 1000 Comments Friend Collector Seventh Anniversary
    Hi @Vyacheslav
    The VPN phase 2 is configuration of VPN Connection.
    You can make sure if your configuration is correct.
  • Vyacheslav
    edited May 2019
    Thanks for the answer, but my settings are the same as yours except 3DES, which is missing from me on ZyWall 110 (firmware 4.33).
  • Vyacheslav
    edited May 2019
    May be downgrade firmware to 4.25?
  • Vyacheslav
    from 4.33 realase
    IPSec VPN
    1. [SPR: 070814168]
    [Symptom]
    VPN tunnel could not be established when:
    a. a non ZyWALL/USG peer gateway reboot and
    b. ZyWALL/USG has a previous established Phase 1 with peer gateway, and the Phase 1 has not expired yet. Under those conditions, ZyWALL/USG will continue to use the previous phase 1 SA to negotiate the Phase 2 SA. It would result in phase 2 negotiation to fail.
    [Workaround]
    User could disable and re-enable phase 1 rule in ZyWALL/USG or turn on DPD function to resolve problem.
    its my situation, but  me that dont help.
  • Vyacheslav
  • Zyxel_Stanley
    Hi @Vyacheslav
    Can you have a check L2TP connection setting on your PC?
  • Vyacheslav
    Thank you all! The problem was that as a test computer I used a home with Windows 10, and VPN started working after "regedit"==> "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\PolicyAgent"==>parameter "AssumeUDPEncapsulationContextOnSendRule" "Value Data" it was changed from "2" on "1". I express special thanks to the user "[Zyxel] jonatan" for actively participating in solving my problem.
  • Zyxel_Stanley
    Hi @Vyacheslav
    The registry key 2 you mentioned is for establish VPN when both USG and client are behind NAT router. In your scenario, USG should not behind NAT, the value 1 is enough.
    It’s good to hard you resolved the issue. :+1:
