USG Flex 200 allow a specific URL
henriquev
henriquev Posts: 19 image  Freshman Member
We have a need to allow a specific youtube URL like:
https://www.youtube.com/watch?v=cOG7j9C4kVs&ab_channel=FazendoNerdice
on top of our security policy that blocks the youtube as a whole.
Is it possible to accomplish this using an USG Flex 200 registered on Nebula?
  • Zyxel_Tina
    Zyxel_Tina Posts: 402 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 50 Answers First Comment
    Hi @henriquev,
    Regarding your requirement to allow to a specific YouTube URL you've mentioned while blocking YouTube as a whole, we would like to clarify that this is not achievable on Nebula.
    The reason is that the whitelist feature for website filtering does not support full URL paths (such as /watch?v=...). It only allows domain-level filtering (e.g., youtube.com, docs.google.com, etc.).
    We apologize for the earlier confusion and appreciate your understanding.
    Zyxel Tina
  • Zyxel_Tina
    Hi @henriquev,
    Please refer to this FAQ for instructions on configuring access to specific websites.
    Zyxel Tina
  • Zyxel_Tina
    Hi @henriquev,
    Zyxel Tina
    PeterUK Posts: 4,228 image  Guru Member
    Their might be two ways it could be done one is that YouTube use http and USG looks deep to all a full URL path the other is the use of SSL inspection to see the full URL path.
Nebula Tips & Tricks
