USG40 simultaneous dual ppoe disconnections
James
James Posts: 2 image  Freshman Member
edited April 2021 in Security
I'm having an problem with a USG40 with dual WAN connections to separate modems. Both connections seem to drop out frequently and either simultaneously or in quick succession. Both are to separate modems on separate ADSL lines. MTU is set at 1492 for both, and both lines perform well so long as they remain connected. Dropouts can occur days or minutes apart, but usually seem to happen in long clusters, but only for a few seconds at a time - the USG redials and reconnects within a few seconds. See screenshot for illustration.
I've checked and rechecked the config and can't find any issues. I've rebooted the USG which doesn't solve the problem. I've also removed the session limit as suggested somewhere else, to no avail. Any ideas?
  • Zyxel_Stanley
    Hi @James
    The most of ISP will disconnect the PPPoE connection a couple of days. (It is defined by different ISP) And It is normal behavior.
    If nail-up function has enabled, USG will reconnect after ISP disconnected it.
  • James
    Hi @Zyxel_Stanley
    Thanks for your response, but this isn't the answer. The nailed-up function is already enabled for both ppoe interfaces. The interfaces already do reconnect a minute or so after disconnecting, but disconnections are so frequent (often every few minutes) that this still amounts to significant down-time. I have already asked the ISP and they are not disconnecting the ppoe at this frequency, and certainly not simultaneously on both lines.
  • Zyxel_Stanley
    I will check this issue by private message for more details.
