SWITCH GS-108B V5 After a few hours of work, the connected devices lose connection
Neodixi
Neodixi Posts: 1 image  Freshman Member
After a few hours of work, the connected devices lose connection. They are a voip phone, a PC a printer, and another generic switch, star center.
The problem is not the other switch because all the connected devices work very well.
I turn it off and on again and it works again until about the next day!
My doubt is that the GS-108B V5 is too poor or is it defective?
Do you have ideas or suggestions?
Thank you
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 410 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    edited August 2025
    Hi @Neodixi,
    I suggest you can isolate the network, and you can deploy two Pcs under the same network.
    Then conduct a continus ping test to see the result.
    Thanks.
    Ivan
