GS1900-8HP MIB
Hello everyone,
I would like to integrate my GS1900-8HP switch with my Zabbix supervision via SNMP.
I have downloaded the MIBs from the official website : here.
However, the OIDs of these files do not correspond to what the switch sends me.
For example, to retrieve the model I use this command, which returns an OID :
snmpget -v 2c -c public -On 192.168.1.251 ZYXEL-ES-COMMON::sysProductModel
.1.3.6.1.4.1.890.1.15.3.1.11 = No Such Instance currently exists at this OID
But when I use snmpwalk I notice that it's not the right OID that's being integrated.
And when I go directly to the OID it works:
snmpget -v 2c -c public -On 192.168.1.251 iso.3.6.1.2.1.1.1.0
.1.3.6.1.2.1.1.1.0 = STRING: "GS1900-8HP"
On my switch snmp is activated with the default community :
What's more, my switch is also the latest version :
Does anyone have an idea as to why I'm having this problem?
Thank you in advance,
Best regards.
This could be an issue on your Zabbix configuration. You can check this post which seems have a solution: SNMP "No such instance currently exists at this OID" : r/zabbix
I used iReasoning MIB Browser to get .1.3.6.1.4.1.890.1.15.3.1.11, and I can get the correct information.
Accorrding to your snmpwalk result, it shows that it used the public MIB/O.I.D. to get the information. GS1900 supports Zyxel private MIBs and public MIBs, so you can use the .1.3.6.1.4.1.890.1.15.3.1.11 or .1.3.6.1.2.1.1.1.0 to get the product model information.
Zyxel Melen0
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
