How to display hostname in traffic statistic ?
Asgatlat
Asgatlat Posts: 114  Ally Member
First Comment Friend Collector Seventh Anniversary
on my Flex200H (FW 1.35), i want to see hostname of ip client in traffic analysis.
when you go to Network status > Devis Insight > you can see client ip and their computer hostname
but when you go to Traffic Statistic > Application usage > you see the ip adress but no more hostname. how to add hostname in column ?
  • Zyxel_Tina
    Zyxel_Tina Posts: 110  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 25 Answers First Comment
    Hi @Asgatlat,
    Currently, the hostname is not displayed in the Traffic Statistics > Application Usage view.
    To better understand your needs, could you please share a bit more about your use case? For example, how would displaying the hostname in this section help with your workflow or network monitoring?
    Your input will help us evaluate this feature more effectively.
    Zyxel Tina
  • Asgatlat
    Hi @Zyxel_Tina
    this could help me to identify a host who use abnormal traffic for exemple
