How to display hostname in traffic statistic ?
on my Flex200H (FW 1.35), i want to see hostname of ip client in traffic analysis.
when you go to Network status > Devis Insight > you can see client ip and their computer hostname
but when you go to Traffic Statistic > Application usage > you see the ip adress but no more hostname. how to add hostname in column ?
Best Answers
Hi @Asgatlat,
To display the hostname in the Traffic Statistics > Application Usage view, please refer to the following steps.
- Navigate to System > Advanced to turn on the "Device Insight" toggle
- Once enabled, the toggle allows you to see the hostname in the Client Description section on the Application Usage page.
Zyxel Tina
Hi @Asgatlat,
Correct. The Gold Security Pack license includes the Device Insight service. If a license has expired, you will see a reminder in this screen. You need to renew the license in order to keep using the feature.
Zyxel Tina
Hi @Asgatlat,
Currently, the hostname is not displayed in the Traffic Statistics > Application Usage view.
To better understand your needs, could you please share a bit more about your use case? For example, how would displaying the hostname in this section help with your workflow or network monitoring?
Your input will help us evaluate this feature more effectively.
Zyxel Tina
Hi @Zyxel_Tina
this could help me to identify a host who use abnormal traffic for exemple
Hi @Asgatlat,
Zyxel Tina
Hi @Zyxel_Tina
it seems i need gold security pack licence for this 😯
Hi @Asgatlat,
Zyxel Tina
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
