Clients Page Search by VLAN
SkyGoat
in Nebula Ideas
In the Site-wide > Clients page, the "All" search box doesn't have an option to search by VLAN. Can this please be added.
I know that if you select "Access point clients", "Switch clients" or "Security gateway clients", then you do have the option to search by VLAN, but would like to have this ability on the "All" list as well.
3
While you are at it, add a field to search by client name.
Actually, I would suggest you add search/filter fields dynamically to the search list based on which fields are selected for view in the chart. There by making all of those data points to be fields which can be used to filter down your view. The name and VLAN each being in that list already.
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 495 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 48 Wireless Ideas
- 286 Service & License
- 456 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
