change rule via cli
Heimo
Heimo Posts: 5 image  Freshman Member
Dear all,
my name is Heimo and this is my first question. I am not a Firewall specialist and so i changed a rule (webinterface from LAN) unintentionally from allow to deny and so I am not able to access the web gui. For this gui my knowledge is ok.
Does anybody know how to change a secure-policy of a FLEX-100 from deny to allow via cli?
Kind regards
Heimo
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,259 image  Zyxel Employee
    Hi @Heimo
    Please try to:
    1. Login to your firewall via SSH/Console.
    2. Use the command "show running-config" to identify this security policy. For example: "secure-policy 8".
    3. Use the command "configure terminal" to enter the configuration mode.
    4. Enter the security policy you found in step 2 to enter the editor mode for this policy.
    5. Use the command "no activate" to disable this policy.
    6. Remember to exit the configuration mode and enter write to save the changes.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Heimo
    Please try to:
    Zyxel Melen
  • Heimo
    Dear Zyxel_Melen,
    thank you very much, a few minutes ago I could change it. I had to allow a rule, which I
     i changed unintentionally from allow to deny . It was only the syntax I did not know.
    I did this:
    - configure terminal
    - secure-policy 28
    - action allow
    - service https
    - exit
    - write
    And now it works. Thank you very much for trying to help me. I learned a lot by trying very hard to find a solution.
    Greetings from Austria
    Kind regards
    Heimo
