H series 1.35 FW download is impossible
2»
    PeterUK Posts: 4,018  Guru Member
    edited August 11
    Yes I get your point so in short the base firmware needs all the WAN config be it MAC, DHCP, static or PPPoE to get on your internet which is not the case at this time? guess Zyxel thinks you have a router setup to give a IP to a setting up device or your internet line will give a IP by DHCP but what if you don't then your stuck.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,744  Zyxel Employee
    Hi @GateArray
    The firmware files are sent to you via the private message.
    Zyxel Melen
  • Zyxel_Melen
    Update:
    The firmware file download for USG FLEX H series will be available on August 20th in the Zyxel Download library.
    Zyxel Melen
  • GiuseppeR
    GiuseppeR Posts: 456  Master Member
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
    Thanks a lot 😎
