H series 1.35 FW download is impossible
Yes I get your point so in short the base firmware needs all the WAN config be it MAC, DHCP, static or PPPoE to get on your internet which is not the case at this time? guess Zyxel thinks you have a router setup to give a IP to a setting up device or your internet line will give a IP by DHCP but what if you don't then your stuck.
Update:
The firmware file download for USG FLEX H series will be available on August 20th in the Zyxel Download library.
Zyxel Melen2 -
Thanks a lot 😎
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
