Does USGFLEX100AX support software VPN clients?
Hi @Jmax77,
Welcome to Zyxel Community!
The USG FLEX 100AX supports software-based VPN clients, such as
- Windows Native VPN
- Zyxel SecuExtender
However, OpenVPN is not supported on the USG FLEX 100AX. This protocol is only available on the USG FLEX H series.
Zyxel Tina
Hi @Jmax77,
Zyxel Tina
I have no trouble getting the SecuExtender to connect. Windows native VPN will not. How should I have the VPN connection configured in the Windows 11 VPN native client? Does Windows require L2TP? I've managed to get this gadget all set up with very little help- which is demonstrative of the simplicity of the Nebula system. I'm just at the very last stages of getting everything working.
Yes Windows 11 VPN native client does work depending on how you set it up
like for L2TP/IPsec with per-shard key you need to setup as IKEv1 Phase 1 with Phase 2 Encapsulation Transport then you need to setup the Phase 1 and Phase 2 Proposal windows defaults but can be change by here for more info here
Phase 1
3DES SHA1
key group DH2Phase 2
Local policy 0.0.0.0
AES256 SHA1
PFS none0
- 441 Beta Program
- 530 USG FLEX H Series
- 332 Security Ideas
- 51 Wireless Ideas
- 294 Service & License
- 461 News and Release
