WAN and VLANS
Hey everyone, how are you? I need some more help. Look, I have two WANs, WAN1 and WAN2, and I also have two VLANs, VLAN40 and VLAN50. VLAN40 goes through WAN1, and VLAN50 goes through WAN2. I'd like to create a rule that when WAN1 goes down, VLAN40 automatically switches to WAN2, and when it comes back up, VLAN40 returns to WAN1. How could I do this?
The way it can be done is routing rules with ping check
so in order
rule 1
incoming VLAN40
next hop WAN1
ping check to some reliable IP that routed some hops a away.rule 2
incoming VLAN40
next hop WAN2and thats it when ping fails for rule 1 rule 2 takes over and you can do the same for VLAN50
Sorry, I'm using the USG FLEX 200. Could you show me with pictures how to do this setup?
the status goes red when ping fail going to the next rule 2 and when ping is back up rule 1 takes over again
- 435 Beta Program
- 183 Nebula Ideas
- 120 Nebula Status and Incidents
- 6.2K Security
- 440 USG FLEX H Series
- 299 Security Ideas
- 80 Switch Ideas
- 276 Service & License
- 433 News and Release
- 84 About Community
- 91 Security Highlight
