IP/MAC Binding on Flex H series
Hello community,
is it possible to configure IP/MAC binding as it is in the "interface" settings of the ATP GUI?
I cannot find it, nor on-premise nor in the nebula configuration
I found a more or less recent FAQ about MAC binding here but it just refers to the ATP GUI.
Thanks😜
So tested it out seems to work "Source IP Spoofing Prevention" where by any static IPs are blocked unless allowed by Trusted IP.
and any Reserved IP/MAC that you make static are allowed even if not in Trusted IP but with Include DHCP Leasing Entries on
Hi @QuiteSmart
This feature is renamed as "IP Spoofing Prevention."
FAQ: USG FLEX H Series - Source IP Spoofing Prevention — Zyxel Community
Zyxel Melen0 -
Then you @Zyxel_Melen ,
does it work even when some mac addresses have the IP locked with DHCP reservation?
guess thats what the "Include DHCP Leasing Entries" toggle is?
unless your looking for this?
Hello @PeterUK I hope you had/are having nice vacations,
I must admit that since @Zyxel_Melen reply I still have to test it
What I would like to get is the following:
- DHCP is on that interface
- I have some devices with DHCP reservation in place (like in @PeterUK screenshot)
- In case a host connects with DHCP he is alllowed
- In case a host connects with a static IP it is banned and log alert reported
- Hosts with DHCP reservation are allowed and DHCP reservation takes place
- Eventually (since i saw something that seems alike) i can whitelist some ip addresses (in case a host presents itself with that static IP it is allowed)
It seems to me that everything can be done I just wanted to double check on the DHCP reserved hosts since AFAIK on ATP series they were not allowed in such a scenario
SO your looking for the "Enable IP/MAC Binding and DHCP Enforcement" ?
yes, sir!
your "guru member" status is well deserved, thank you mate!
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
