ZyWALL USG60 no port forwarding when dual WAN
Hi all,
that's the problem: when the USG60 is connected with a single WAN the port forwarding works flawlessly; when I plug in the second WAN the forwarding is not working anymore.
The port forwarding rules are configured ok, maybe the problem is related to the dual WAN failover capability?
To make work the WAN failover I followed the instructions of the official video on YouTube ZyXEL channel:
Any ideas?
Thank you!
P.S. One more info: there's a typo in my nickname, I searched everywhere to change it but I found nothing...!
2
Hi, I'm not sure but I think that the WAN failover is only for outgoing traffic. For port forwarding in the NAT configuration you only specific one incoming interface, if you have a second WAN link you need create the rule for this too.
incoming interface: WAN 1 -> external port 4444 -> internal port 3389 -> internal ip
incoming interface: WAN 2 -> external port 4444 -> internal port 3389 -> internal ip
I think that if your inbound trafic is from the WAN1 and your failover is directing the outgoing traffic to the WAN2 the port forwarding will not work. For port forwarding the traffic should occure in the same WAN for inbound and outgoing traffic.Correct me if I can go wrong.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
https://www.youtube.com/watch?v=jogTfujoHkI
