USG FLEX H Series - V1.35Patch 1 Firmware Release
Zyxel_Melen
Zyxel_Melen Posts: 4,136 image  Zyxel Employee
Zywall USG FLEX H Series Release Note
August 2025
Firmware Version on all models
  • Please use the cloud firmware upgrade function to upgrade USG FLEX H Series
USG FLEX H SeriesFirmware Version
FLEX50HV1.35(ACLO.1)C0
FLEX50HPV1.35(ACLP.1)C0
FLEX100HV1.35(ABXF.1)C0
FLEX100HPV1.35(ACII.1)C0
FLEX200HV1.35(ABWV.1)C0
FLEX200HPV1.35(ABXE.1)C0
FLEX500HV1.35(ABZH.1)C0
FLEX700HV1.35(ABZI.1)C0
New Feature and Enhancements
N/A
Bug Fix
1. [eITS#250501586] RADIUS logs cause memory issues, leading to unexpected reboots.
2. [eITS#250701932] Security policy cannot detect the user or user group.
3. [eITS#250701854] IKEv2 login with AD user is not working when ext-group-user is selected in Remote Access VPN > Authentication > User.
Please refer to the Download Link for more details.
Zyxel Melen
  • e_mano_e
    e_mano_e Posts: 114 image  Ally Member
    First Answer First Comment Friend Collector Fifth Anniversary
    I would like to read more about "[eITS#250701932] Security policy cannot detect the user or user group.".
    Can you use the eITS number to read more about it?
    If so, where?
    And also the question: What does eITS stands for?
    Thanks.
  • Zyxel_Melen
    Hi @e_mano_e
    No, eITS is the ticket system that Zyxel uses, which is not an open system that allows the end customer to view all the tickets. The ticket you are asking about is that when you set a deny security policy for a user or a user group, it will be skipped if the traffic matches this policy. We list the ticket number that our customers use to identify if their issue has been fixed in this firmware version.
    Zyxel Melen
