Wifi controller migration
David_HBD
David_HBD Posts: 3 image  Freshman Member
Hi all,
I’m migrating Wi‑Fi management from an ATP200 to a USG FLEX 700H (FW version V1.35(ABZI.1)) however I am facing some issues.
The problem is that I am not able to register the APs on the FLEX. When I remove one of the APs from ATP200 management by clicking on the Remove button (so far I removed just the one since I need the wifi network to be running in the facility), the AP does not appear on the FLEX under Unmanaged APs list.
The AP model is Zyxel WAC6303D‑S.
What I already tried
  • Set DHCP Option 138 on the FLEX (scope for VLAN99) to the exact IP of the FLEX on VLAN99.
  • Verified trunks: VLAN99 and client VLANs are tagged on all switch links between APs and FLEX.
  • Performed a light reset/reboot of the problematic AP.
  • Confirmed that on AP adopted earlier on the FLEX operate normally (SSID broadcasting, clients obtain IP).
After this, the AP does appear in the ATP200 for registration, but does not apper in the FLEX device and I do not seem to be able to get it under the FLEX management.
When I first updated the FLEX device to the firmware supporting wireless, I was able to register one of the unused devices. I was able to set it up correctly and it works and provides stable connection - I am meantioning this to demonstrate, that the FLEX is setup correctly and is ready for managing APs.
Could somebody, please, give me an advice on how to migrate the APs managed by ATP 200 under FLEX management?
Thank you!
  • Zyxel_Tina
    Zyxel_Tina Posts: 699 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @David_HBD,
    Thank you for sharing the detailed troubleshooting steps.
    We have reviewed your case and can confirm that the reason your WAC6303D-S APs cannot be adopted is due to compatibility limitations. The USG FLEX H series (including the FLEX 700H) does not support older AP models such as the WAC6303D-S.
    Regarding supported AP models on the USG FLEX H series, firmware V1.35 (Patch 1) supports only the following: WAC500H, WAX300H, WAX510D, WAX610D, WAX620D-6E, WAX630S, WAX640S-6E, WAX650S, WAX655E, WBE510D, WBE530, WBE630S, and WBE660S.
    Zyxel Tina
  • Zyxel_Tina
    Hi @David_HBD,
    Zyxel Tina
  • David_HBD
    Hi, Tina,
    thanks for the response. Will the older models be supported in future fw updates?
  • Zyxel_Tina
    Hi @David_HBD,
    Since the WAC6303D-S is already an End-of-Life (EoL) model, there are no plans to support this AP on the USG FLEX H series (including the FLEX 700H) in future firmware updates.
    Zyxel Tina
