Unable to delete interface
PeterUK
PeterUK Posts: 4,147 image  Guru Member
edited August 21 in USG FLEX H Series
FLEX H V1.35
seems like if name has "_" in it
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,990 image  Guru Member
    Hi @PeterUK
    This issue is because this interface is still selected in two-factor authentication.
    Please change this interface and you will be able to delete this interface.
    Zyxel Melen
  • Zyxel_Melen
    Hi @PeterUK
    I tried in my lab but can't reproduce this issue in V1.35 P0, P0 weekly firmware, P1 with the interface name "_". We will access your firewall to check this issue and update you once I get further information.
    Zyxel Melen
    Hi Melen
    not sure if this is a problem but the the running firmware is
    V1.35(ABWV.0)ITS-25WK31-m8810
  • Zyxel_Melen
    Hi @PeterUK
    Zyxel Melen
    Thanks Melen
    That did it
